Trying to stay consistent with the previous oil in the bike and in the reservoir its blue. I was told its Motul but would like to keep it consistent. Thanks in advance! _________________ Keep the Rubber Side Down
If you're concerned about it, maybe just drain it and replace with the new stuff? Mixing oils is generally unproblematic though unless you are trying to mix vegetable stuff with mineral stuff. In your kind of situation I tend to just run the old stuff til the tank's almost dry and then top up with the new stuff. _________________ Still smoking...
Must be an equator thing because when I pour some into a clear container, it is a dark green. Toilets flush the other direction down there too, right? _________________ -Jim
'93 MC21
