base gasket removal
Jim
base gasket removal
Tue Oct 05, 2010 4:41 pm » Post: #1 » Download Post
okay, so I am in the middle of my first top-end attempt, so be gentle. Can someone give me some tips on the best way to remove the old base gasket from the cylinder? I'm pretty sure it was fit dry so it is really on there. I know it is crucial not to scratch the cylinder surface, so I'm wondering if there is something in particular people use to soak the paper gasket or other technique/tool that people have found effective and safe. ANY constructive advise would be appreciated.
Thanks.
-Jim
'93 MC21
bushman
Tue Oct 05, 2010 4:56 pm » Post: #2 » Download Post
A gasket scraper is the tool you need.
Tue Oct 05, 2010 5:00 pm » Post: #3 » Download Post
By their nature, and because of the job they do, base gaskets don't really respond much to being soaked... they're pretty resistant to most liquids!
I've always found that a new Stanley knife blade, held at the shallowest possible angle, is the best thing for gasket removal. The key is to take all the time in the world to scrape the stubborn gasket off carefully.
Just make sure the sharp edge is always in contact with as much of the gasket face as possible. You don't want any sharp corners digging in to the soft alloy.
I generally find there's not enough room to put the blade in a handle, and find I have much more control over it by hand anyway.
Tue Oct 05, 2010 7:57 pm » Post: #4 » Download Post
Basically if they're stuck on badly it's a pain, it can take a good few hours to get it all off. I don't know why some stick that badly, maybe some idiots are using some kind of instant gasket as well.
The cases can be even worse if the motor is in the bike.
I coat the gasket with a smear of grease, it stops them sticking at all and I've never had one leak yet.
Kubira
Wed Oct 06, 2010 5:50 am » Post: #5 » Download Post
i have had to do this a few times myself and after several new gaskets, it seems they all like to stick. Andy's method is the most common and to add to it, a bare stanley blade works well with a few layers of tape wrapped around your thumb.
RichG
Wed Oct 06, 2010 8:09 am » Post: #6 » Download Post
I'm with Fontyyy, a thin smear of grease and they don't stick.
I've spent many hours removing dried out / welded on gasket material, when breaking down engines for the first time (since I had them).
Rich
KTM39
2009 KTM 530 EXCR
Wed Oct 06, 2010 8:56 am » Post: #7 » Download Post
I removed my base gaskets today and found that a spray of Brake Cleaner made the 2nd cylinder a fair bit easier. The first one took me about 30 mins, (lubing with CRC water dispersant and the 2nd one was about 10 mins).
I scraped them with a new razor blade.
Wed Oct 06, 2010 12:16 pm » Post: #8 » Download Post
I smear my gaskets with Castrol Lithium grease. Works a treat. After a couple of fun weekends on the RS250NX5 I pulled off the cylinders and the gaskets came off like new. No signs of sticking.
I've tried various other greases and they still tend to stick a little over time.
Jim
Wed Oct 06, 2010 3:56 pm » Post: #9 » Download Post
Yeah, assuming I ever get to that point, I'm going to mount the new gaskets with a smear of grease.
KTM39, what is your secret? I started in on them with Stanley blade and brake cleaner and after 30 minutes I was maybe a quarter of the way done with one cylinder! Either mine are stuck on there worse or my technique is wrong (or both), but this is taking forever. Maybe I'm being too cautious? Are you getting any large pieces at a time to come off - I'm getting only balled up, mushy shavings.
It seems like some mad chemist should have come up with something that dissolves paper gaskets without harming metal. Idea Thanks everyone for the tips.
-Jim
'93 MC21
pbekkerh
Wed Oct 06, 2010 5:39 pm » Post: #10 » Download Post
Well he did and there are many other products.
I've used one and a plastic scraper. It worked OK but it did take more than 10 minutes but I don't care as long as the gasket is removed without damage to the surfaces.
http://www.beltco.com.my/catalog/PERMATEX/PERMATEX-GASKET-REMOVER-4MA/
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
Jim
Wed Oct 06, 2010 6:07 pm » Post: #11 » Download Post
I did try brake cleaner and it didn't do all that much, but I'll try the Permatex to see if that works better, thanks.
-Jim
'93 MC21
KTM39
2009 KTM 530 EXCR
Wed Oct 06, 2010 8:20 pm » Post: #12 » Download Post
1st cylinder I got no pieces bigger than about 5mm, (using CRC).
2nd cylinder I pulled off a few pieces about 25mm, (using brake cleaner).
It's possible that the gasket on my 2nd cylinder just wasn't stuck on as stubbornly as the first one, but either way, job's done and my barrels are back on.
I'll post up some pics later - right now, I want to get back into the shed and fit my new Tyga pipes!
Thu Oct 07, 2010 1:43 pm » Post: #13 » Download Post
I do have a gasket scrapper, but still find em to thick. I now use my late Gran's butter knife. It's thin enough to get under the gasket without being too sharp to gouge the barrel/cases.
I think StephenRC45 uses something similar..... but not one from my Gran.
Thu Oct 07, 2010 3:01 pm » Post: #14 » Download Post
I used gasket solvent spray which is like paint stripper and a sharp knife blade
