No idea, sounds like you're volunteering to buy one and compare them!? _________________ MC21SP Plaything
That was going to be my next post I think one of mine is failing. Have a dyno session booked on Saturday so will check it out then. Racer38 kindly lent me a coil, which I will take to the dyno to try and diagnose the problem. If it needs a new coil, I will buy a coupe of the NSR125 coils and give it a go.
Before you connect it up, do a quick check to make sure the primary and secondary resistance readings are the same or you may fry something... _________________ MC21SP Plaything
