Will the bottom ends of a RK5 or RK6 work with the R2/4J wire harness?
I understand that there are differences in the ignitiion, but just trying to see if other model mc18 engines will work with what I have.
I have searched and have almost read / skimmed all the 245 threads in the discussion forum and don't remember coming across any info.
I can't see any reason why there would be a problem. There may be a slight difference with the stator or pickup plugs but as you have the old plugs you'd be able to fix that anyway. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
geezagillard wrote:I think I also had to find the neutral wire within the GPS but I'm not sure you will have to deal with this using the R5/6 PGM2?
Correct, the GPS is only on the mc21, all other NSR road loom's just have a neutral sensor. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
