nsr trouble r2j
nsrjb
nsr trouble r2j
Wed Jan 12, 2011 7:04 pm » Post: #1 » Download Post
i started my bike today, and the left hand side exhaust pipe was full of fuel.
so i presume one of carb floats is stuck open????
any ideas??
Wed Jan 12, 2011 8:01 pm » Post: #2 » Download Post
I had the same problem with mine
New float valves help
A new fuel tap made the biggest difference, as only a couple of carbs of fuel will drain down even if the float valves don't do their job
nsrjb
Wed Jan 12, 2011 9:11 pm » Post: #3 » Download Post
my fuel tap is working fine.
anyway the fuel is coming out the overflow pipe on the right carb and out the bottom of the carb bowl.
so i changed the float valve and put on a different carb bowl off a set of mc16 carbs and its still doing the same thing.
i am out of ideas now.
dunkenb
1989 Honda NSR250 MC18
Wed Jan 12, 2011 10:31 pm » Post: #4 » Download Post
Clean the seat for the float valve with a Q tip in a drill and some brasso! Go gently though. Very Happy
nsrjb
Wed Jan 12, 2011 11:03 pm » Post: #5 » Download Post
cleaned the seat for float valve problem is now sorted thanks for the advice Very Happy
