Previously this site helped me identify my engine using the engine number. Engine number says it is MC18 R2J. But then I found that the engine has a gear position sensor.
The MC18 has only a neutral switch. So taking a look at at the serial number again i noticed it has been modified. The old number has been ground out and a new one stamped into the engine case. The size of the numbers do not match and the aluminum has a divot you can feel with your finger.
On the parts manual all MC21 have an o-ring on stator side of crank (located on the bearing i think). MC18 do not. My crank does not. Which is in direct conflict with previously mentioned GPS.
And what is the difference between and MC21/28R and MC21/28SE/SP crank? Tyga sells both.
I am so confused. _________________ MC21R9N track
MC18R2J track
CBR954
CR250
The crank that you have attach in the photo can be either from a MC18 R5 or from a MC21 or from a MC28... All these three cranks use the same bearings... This is what i understand from the photo...
Are you saying that it is not an 1988 MC18 R2K because it does not have a seperate center seal? _________________ MC21R9N track
MC18R2J track
CBR954
CR250
In the crank picture i can see the groove of the center bearing... If the o-ring is there or not well this is another matter... The cases don't have a groove that the o-ring seats... So it's ok...
The center bearing does indeed have a groove for an o-ring indicating it is MC21/28. I stand corrected (yet again).
But just to be sure, someone could have rebuilt MC18R5K using MC21/28 center bearing right?
I understand the only other difference between MC18R5K or MC21/28 crank is web thickness. And that you can mill 2?mm off an MC21/28 crank to make it fit in a MC18 R5K. Does anyone know what web thickness' dimensions? _________________ MC21R9N track
MC18R2J track
CBR954
CR250
