This is a 21 with an R engine and wire splice. When it last stopped, it was running OK except for the leaking exhaust port. What did I do after? removed the airbox and put it on again without mods (just for peeking), removed the plugs so see the colour (dark tan), remove the TPS to check the valves, I think that's all.
Now, it does not start either kicking or pushing. Some details:
- the fuel valve is not tight. I learned this when I removed the tank. It leaks even in the closed position.
- the powervalve does not cycle when the ignition is turned on/off, run switch in either position
- battery voltage is 12.52. Lights, blinkers, etc working.
I have the following suspects: battery, exhauts flanges incorrectly seating, airbox incorrectly connected to carbs, carbs/cylinders flooded, unkonown disconected wire/connector,...
When kicking/pushing there is no sign of an explosion the engine. (by the way, the clutch drags a litle bit when pushing). There seems to be compression...
What should I do next?
