I second that, some real nice power. What is reliability like?
I assume you're using the Tyga 300 kit. Are you running VHM heads too? What pipes are you using and are you running a modded airbox?
Hi ,
I am using the cast 300 pistons until i receive the wiseco's . I have done 2 races with no problems on these pistons .
I am using Tyga pipes but have some custom made pipes coming at the end of the month .
I am using 38mm carbs on my motor so no airbox .
The 1st graph i still had a splutter , i found out that my plugs were the cause .
2nd graph was with new plugs and it pulled clean , i don't know why the operator set the limit at 11250 . My bike normally peaks around 11500 but has over rev to 12 or 13 by accident .
No secrets on the power , all mods have been posted . The main thing to show was what mod gave an increase . Foget about the hp figure look at the change in curve etc .
