ok what do you guys use when you remove the oil pump to blank off were it sits, on my aprilia i had a blanking plate so nothing got inside the engine, on my 28 it has been left open _________________ if dont fall off every now and then your not trying hard enough
HRC has a block off plug, as does TYGA. Or you could make your own. Cut a piece of aluminum into shape and use the mounting bolts/holes to attach it. Get some gasket material and cut that to shape to seal it.
i dont kow i got the bike monday and when i started this thread i noticed there was nothing blanking it off i will imvestigate further at some point but its not getting run at the moment but its first on my list of things to do when i go over it all
