15mm rod conversion
2T Institute
15mm rod conversion
Wed May 25, 2011 4:07 am » Post: #1 » Download Post
Anyone ever converted to a rod to use the 15mm gudgeon?
NSR-lizard
Wed May 25, 2011 12:02 pm » Post: #2 » Download Post
Question
Vampire?
Wed May 25, 2011 1:05 pm » Post: #3 » Download Post
The stock road NSR250 uses 15mm piston pins anyway?
There's no sane reason to convert to another size.
Neal
Wed May 25, 2011 6:42 pm » Post: #4 » Download Post
All depends on what motor/crank you have .
Thu Jun 02, 2011 10:19 am » Post: #5 » Download Post
fontyyy wrote:The stock road NSR250 uses 15mm piston pins anyway?
Could convert RS NF5 rods which use a 14mm piston pin. Less reciprotating weight. That's a sane reason.
