pump settings
tom tom
pump settings
Fri Jun 10, 2011 4:35 pm » Post: #1 » Download Post
Hi got my mc21 a few days ago so just going through it and want make sure oil pump is set up right, on other bikes iv'e had you just take a screw out of one of the carbs open throttle until a mark on the slide is visible through the screw hole when you can see that a mark there was a line on the pump cable arm that should line up with mark on pump body is is similer on the mc21 had a look in the search but no luck can anyone help, i know so far all ive post on here are questions for help but when i'm all up to date with the bike maybe i can help someone.
javes
Fri Jun 10, 2011 5:38 pm » Post: #2 » Download Post
http://tech.nsr-world.com/nsr/nsr-all/oil-pump/
{.bLanK}GoD
Re: pump settings
Sat Jun 11, 2011 1:40 am » Post: #3 » Download Post
tom tom wrote:Hi got my mc21 a few days ago so just going through it and want make sure oil pump is set up right, on other bikes iv'e had you just take a screw out of one of the carbs open throttle until a mark on the slide is visible through the screw hole when you can see that a mark there was a line on the pump cable arm that should line up with mark on pump body is is similer on the mc21 had a look in the search but no luck can anyone help, i know so far all ive post on here are questions for help but when i'm all up to date with the bike maybe i can help someone.
Dude! What would be more helpful to us is if you worked on your grammar a bit.
Follow the guide javes posted, it's pretty hard to cock up.
tom tom
Sun Jun 12, 2011 2:08 pm » Post: #4 » Download Post
Hi i did follow the the guide and it was helpfull.
