nsr250 mc18 gearbox oil ?
daz2011
Mon Jul 25, 2011 8:17 pm » Post: #1 » Download Post
hi there folks, can anybody help with advice on what sort of oil i should use when changing the gearbox oil on my mc18 version 1 1988, and also the filling amount and is it filled on the side stand or upright, hope to hear from some of you soon, daz.
Neal
Mon Jul 25, 2011 9:01 pm » Post: #2 » Download Post
Hi , I use Motul gearbox oil , I can't remember how much to put in but you will find that answer in main site engine section . Drain it , pour new oil in and your good to go .
NSR-lizard
Mon Jul 25, 2011 11:32 pm » Post: #3 » Download Post
Oil specification can be found here:
http://www.nsr250.net/forums/members/web_manual_mc18_21/
Maintainance schedule and notes here:
http://www.nsr-world.com/workshop/maintenance/
General MC18 Mk1 specs here:
http://www.nsr-world.com/specs/html/nsr250/mc18/mc18-1/
It`s all on the website if you look for it!
Vampire?
nsrdownunder
1993 Honda nsr 250 mc21 sp
Tue Jul 26, 2011 5:36 am » Post: #4 » Download Post
I`ll second the motul full synthetic 2stroke gearbox oil they take around the 800ml from memory but fill with bike upright .
NSR-lizard
Tue Jul 26, 2011 5:49 am » Post: #5 » Download Post
You want to be careful running fully synthetic with a wet transmission. Not all are compatible, and can cause clutches to slip.
Also, fully synthetic tends to be rather expensive, and a wet clutch will contaminate it quickly as it wears.
Vampire?
nsrdownunder
Tue Jul 26, 2011 8:06 am » Post: #6 » Download Post
the motul is sweet from there site - Specially formulated for gearboxes with wet clutches in 2-stroke motorcycle engines,
TRANSOIL EXPERT 10W-40 delivers smoother
gear shifting under extreme and severe conditions. With the inclusion of a specific gear additive, TRANSOIL EXPERT 10W-40 provides superior clutch performance. For gearboxes without wet clutches, use GEAR 300, MOTYLGEAR or GEARBOX.
It is only $20 here in aus so not to expensive
anonymous.shyster
Tue Jul 26, 2011 8:09 am » Post: #7 » Download Post
Fully synthetic oil in a wet clutch gearbox will be fine, provided that it does not have friction modifiers added. All motorcycle specific engine and gearbox oils do not have the modifiers that cause the clutch to slip.
I recently put in genuine Honda four stroke GN4 oil in my NSR gearbox (it took 800ml). Took it for the first ride today, and the shifts are incredibly smooth. Previously I was using shell gear oil and for some reason it was very notchy.
Procedure for filling with oil - just pour it in. Put 700ml in to start with then hold the bike upright so that it is balanced and check the level with the dipstick while it is upright. You only dip the dipstick in the hole - do not screw it in. Add oil until it is filled to the top mark on the dip stick.
anonymous.shyster
Tue Jul 26, 2011 8:11 am » Post: #8 » Download Post
I paid $10 for a litre of the GN4, btw.
Dmitry
Wed Sep 05, 2012 1:26 pm » Post: #9 » Download Post
Resurrecting old oil thread, is it winter yet?
Manual recommends SAE 10W30 4 stroke engine oil (that's what all Honda cars run in manual trans) any reason not to run it?
Wed Sep 05, 2012 1:37 pm » Post: #10 » Download Post
Not really, but oil technology has moved on considerably since Honda specified that for the NSR 25 years ago.
Remember too, transmission losses that could be experienced with a lower quality/standard of oil will mean much more to a 60hp 2-stroke than they will to a 120hp bore-stroke.
Dmitry
Thu Sep 06, 2012 3:41 am » Post: #11 » Download Post
Thanks again for advice!
Picked up 80W85 HP trans oil which is rough equivalent of 20W30 motor oil, my local Honda guy swears by it.
