If it has a 15mm piston pin then it not an NF5. I'v not seen a crank case inducted RS motor with a piston ported type piston between 1987-1992. _________________ If I have to take the carbs off once more...
ND5 is the Honda RS250 but before NF5's... Although i checked my parts lists of the ND5 machines and i sew also that the pistons don't have any ports...
