ERR2 in LO position only
joeking78
Fri Sep 02, 2011 10:47 am » Post: #1 » Download Post
Noticed this morning when playing around with the bike that I get ERR2 when the servo sweeps to LO position.
There is no EER2 when it moves to HI and it moves all the way to LO then comes on. The cables are no where near tight in either position and the pulleys move freely, also there is no noise from the servo to suggest it's struggling.
Anyone have any idea what it could be?
NSR-lizard
Fri Sep 02, 2011 1:24 pm » Post: #2 » Download Post
A search for "ERR2" returns 10 results and approx 200 posts.
ERRs on PGM-IVs have been discussed many times. Also, it is covered in great depth in the Service Manual.
Vampire?
cgallant
2001 Honda RS250
Fri Sep 02, 2011 1:31 pm » Post: #3 » Download Post
Short answer is that there is possible carbon build up on the valves or the cables are binding.
joeking78
Fri Sep 02, 2011 1:37 pm » Post: #4 » Download Post
NSR-lizard wrote:A search for "ERR2" returns 10 results and approx 200 posts.
Thanks for the constructive post.
I've been a member here for a while and I'm quite familiar with the search function, however there are no problems like mne where the ERR code appears in LO position only. That's why I asked.
joeking78
Fri Sep 02, 2011 1:38 pm » Post: #5 » Download Post
cgallant wrote:Short answer is that there is possible carbon build up on the valves or the cables are binding.
Thanks Charles.
Can't be carbon as I cleaned them a few weeks back. Cable binding is something I'll check.
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Mon Sep 19, 2011 4:57 am » Post: #6 » Download Post
Check the setting of the TPS.
Loosen off the screw, twiddle the TPS until the light goes out and error disappears and lock it up.
You'll need to measure the voltage from the TPS if you want to set it as per the book.
joeking78
Tue Sep 20, 2011 11:51 am » Post: #7 » Download Post
Matt, that worked a treat thank you! No more ERR2 messages Smile
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Tue Sep 20, 2011 12:39 pm » Post: #8 » Download Post
That's not the correct way to do it but gets you going.
melvin0202
Tue Oct 04, 2011 11:42 am » Post: #9 » Download Post
joeking78
joeking78
