RS250 brakes
sennidott
RS250 brakes
Thu Aug 11, 2011 4:17 pm » Post: #1 » Download Post
I'm looking for a pair of brake discs for my NX5 RS250.
I have these calipers which I want to fit.
No problem there.
The problem is correct discs for these calipers are 290mm diameter not 296mm diameter like the standard NX5 discs.
I have seen a couple of bikes fitted with what I think are the correct 290mm Brembo discs I'm after, an NF5 RS as below and also an MC21 with and NX5 front end fitted to it.
I pretty sure NF5 RS's used 296mm diameter discs?
Am I getting my knickers in a twist over nothing??? What's 3mm between friends... Confused Laughing
Yes, I do know I could just use the standard Honda discs or any other 296mm diameter discs with the correct offset but wheres the fun in that?!
Any help would be appreciated.
Sun Sep 18, 2011 11:05 pm » Post: #2 » Download Post
I'll have a check on the disc size, but I'm sure my NF5 (in the picture) has 296mm disks. They aren't Brembo BTW, they are Sunstar or something.
Brembo do list a 290mm for Hondas, but they have recently updated their website and all I can find is this
http://www.brembo.com/en/Moto/Racing/Prodotti-Competizioni/Documents/Catalogo_Completo.pdf
sennidott
Mon Sep 19, 2011 1:12 pm » Post: #3 » Download Post
racer38 wrote:I'll have a check on the disc size, but I'm sure my NF5 (in the picture) has 296mm disks. They aren't Brembo BTW, they are Sunstar or something.
Thank you for the reply. Yes, I've seen the new Brembo catalogue, but could not find exactly what I was after and a phone call to the Brembo importer was meet with silence...
I be interested to find out more about the Sunstar(?) discs fitted to your NF5.
knedragon
Sat Nov 19, 2011 11:45 pm » Post: #4 » Download Post
warning......if you run these calipers you will need the Brembo Narrow Band racing !!Dont try anything else,things will get ugly.
Steve Wenner
2000 TSR 250
2001 Honda RS250
2001 Honda RS125
2005 Honda RS125
1992 NSR 250-300
1992 NSR50
