Once fitted a 21 arm to the 18, but I seem to recall that it wasn't a permanent fit, just threw it in for a laugh. So, it would seem that it can be fitted without drama, but spacers and what have you may have to be made. The same would go for the 28 swinger I presume.
2Smoke has a Gull-Arm fitted to his MC16, and I knew a guy locally with one fitted to an R5K. The Gull-Arm is a better swingarm, but there is no reason why a Pro-Arm won't fit anything that a Gul-Arm fits. _________________ Andy.
Some argue they look better, and if you're an endurance racer needing to swap wheels in a flash, then they do have an advantage.
However, that comes at a cost: weight. It's pretty logical that a single sided swingarm has to be heavily braced internally to be as strong as a twin-sided swingarm.
Easy to prove it to yourself:
With both hands, hold a wooden spoon (or wheel spindle!) by one end - holding it horizontal. Now have someone press down on the spoon / spindle, and see how easy it twists / moves downwards.
Now hold both ends of the spoon / spindle, and have them do the same thing again. Much less movement, even though its the same two arms / hands holding the spoon.
Whether that weight makes any difference to you is a matter of opinion... Some like the looks and sod the weight, some think a two stroke 250 is meant to be as light as possible, so why make it worse?
How many MotoGP bikes are running single sided arms? _________________ MC21SP Plaything
I have a pair of CBR F3 cartridges from my race bike, they are being shortened and installed in to original MC18 fork. Also I got a hold of MC28 ProArm, almost complete, but I need a wheel, caliper and sprocket. Long winter ahead, I can take some time on this one.
