What do you think about Boyesen 2 stage reeds, I check the search and i saw that it is good but I heard that the second reed is too fat and never open in 250 2 cylinder bikes and it is only for one cylinder dirt bikes!
If the second doesnt open the nsr will have good midrange because the small reed is thin and opens fast but at 10.000 rpm the nsr loose power and the stock are better!
What do you think?
petralism wrote:What do you think about Boyesen 2 stage reeds, I check the search and i saw that it is good but I heard that the second reed is too fat and never open in 250 2 cylinder bikes and it is only for one cylinder dirt bikes!
What do you think?
If they snap then they simply get chewed up by the engine and spat out in a puff of dust...
Carbons quite tough material, I had a reed break up on a KTM and it lunched the big end! Having said that I would be suprised if plastic or glass fibre reeds didnt do the same thing.
paul g wrote:Carbons quite tough material, I had a reed break up on a KTM and it lunched the big end! Having said that I would be suprised if plastic or glass fibre reeds didnt do the same thing.
Four stroke? _________________ MC21SP Plaything
I've got carbon reeds in my NSR, which has done a couple of seasons racing, a bunch of trackdays and a few thousand road miles. No problems so far.
I've also not heard of someone destroying their engine due to reed failure (until the KTM mentioned above!).
All these things are down to an individual to assess the risk and what they're comfortable with. _________________ MC21SP Plaything
Dave Ett wrote:I've got carbon reeds in my NSR, which has done a couple of seasons racing, a bunch of trackdays and a few thousand road miles. No problems so far.
The next order from tyga will have some carbon reeds then
