Just a Quickie..
Hobbit210
Just a Quickie..
Mon Jan 16, 2012 1:35 pm » Post: #1 » Download Post
Got as far as removing the the clutch hub (wet clutch) only to find that my 20mm socket wont fit the nut...as per the workshop section. It is at least 22m.
Is this ok?
Mike
toneless
Mon Jan 16, 2012 2:19 pm » Post: #2 » Download Post
You need a 27mm socket for both wet & dry clutch nut lock.
2t-racelab.com
toneless
Mon Jan 16, 2012 2:22 pm » Post: #3 » Download Post
By the way, 20mm is the size of the thread at the main gear shaft that the nut lock bolts on.
2t-racelab.com
Hobbit210
Mon Jan 16, 2012 8:20 pm » Post: #4 » Download Post
All done...crank out now!
