trouble selecting neutral
fovu
Mon Jan 23, 2012 10:23 am » Post: #1 » Download Post
hi all
took my bike out for a half hour ride today and when i got home i had trouble selecting neutral with the engine on but was easy when i turn it off.it was also a bit clunky going between 1st and 2nd when i was trying to find neutral.has anyone had this issue and can offer some advise?i was thinking the clutch may be worn?it seemed to be going well and changing gears well when i was riding.
bushman
Mon Jan 23, 2012 10:53 am » Post: #2 » Download Post
Chain tension,clutch adjustment within spec?
fovu
Mon Jan 23, 2012 11:04 am » Post: #3 » Download Post
i dont think it is the chain adjustment as it was fine when i first went for a ride,as for the clutch the free play at the lever seems ok but after that i am not sure what adjustment is available.i did notice when i got home and i selected first it did seem to want to go a little bit with the clutch in but only slightly
Mon Jan 23, 2012 9:23 pm » Post: #4 » Download Post
There is an adjuster under the engine - remove the lower fairing panel and follow the clutch cable and you'll find it.
