RC valve oddness
greggo
RC valve oddness
Mon Feb 13, 2012 10:36 am » Post: #1 » Download Post
Not sure what is going on with my RC valve.
I have the HRC loom, HRC box and PGM III. When following the set up instructions for the RC valves they do not open to 'hi' with the ignition on and the TPS unplugged.
The RC valve behaves correctly when I rotate the servo to 'hi' then turn the ignition on (it self closes).
I plugged my spare servo in and it behaves as normal;
Rotate to Hi and turn the ignition on - servo closes
unplug TPS and servo opens
I take it this means my original servo is knackered?
nxrsr20
Mon Feb 13, 2012 7:54 pm » Post: #2 » Download Post
yup, use the new servo
greggo
Tue Feb 14, 2012 9:36 am » Post: #3 » Download Post
Turns out some numpty (not me your honour) turned the servo 180 degrees, so it couldn;t reset all the way to 'closed'.
After taking the cables and thingy off, I turned the bike on and it turned close to 180 degrees. Unplugged the TPS and it set itself to 'Hi'.
Nice. NO need to recruit the spare.
