Stock compression
Don
Stock compression
Fri May 27, 2005 6:45 pm » Post: #1 » Download Post
Was about to go out and check the compression on my '93 SP. Just wondering what it should measure? Around 120psi or so?
Fri May 27, 2005 10:20 pm » Post: #2 » Download Post
It all depends on the port timing. A stock NSR shoudl be around 120psi though.
However Ive tested RS250's which have made almost 80bhp with as little as 45psi! This isnt due to worn rings, just the fact the exhaust ports are so high that the volume of air above it is so small they give a very low compression reading. Of course once the engine is spinning the hight exhaust port comes into its own giving better peak power.
Don
Fri May 27, 2005 10:52 pm » Post: #3 » Download Post
Thanks, both cylinders were right at 120psi. I'm relieved.
Wed Jun 01, 2005 6:19 pm » Post: #4 » Download Post
Good to see they're both the same. Having them equal is as important as the reading.
