gear box shaft ?
Neal
gear box shaft ?
Mon Mar 12, 2012 8:16 pm » Post: #1 » Download Post
Hi guys ,
is the main shaft pressed into the bearing on the round plate of a mc21 dryclutch gearbox ?
Chester362
Mon Mar 12, 2012 8:59 pm » Post: #2 » Download Post
They can be a bit tight sometimes.
Generally, they should just slide in and out easily. Ooh-er missus!
The worst sticking one I've ever encountered was on a gearbox that looked like it had been run low on oil. The bearing and shaft looked like they'd got a bit hot.
MC21 gearboxes are the same ratio-wise for wet or dry clutch set-ups.
toneless
Wed Mar 14, 2012 11:22 am » Post: #3 » Download Post
Normally, on all racing bikes, the mainshaft slides easily out of the bearing holder
though I have dismantled a few nsr250 gearboxes for inspection and all of them had the mainshaft stuck.
Renewing the bearings didn't helped, #800 wet & dry sandpaper didn't helped as well. Rolling Eyes
I suspect that lack of lubrication and poorly maintenance e.g worn bearings, lead them to this condition though I can't really tell for sure.
2t-racelab.com
Sat Mar 17, 2012 9:36 am » Post: #4 » Download Post
I used to spin my shaft up in the lathe and give it a bit of a dress up with some wet & dry so that it slid in and out perfectly. Nothing worse that having to hit my shaft with a mallet while trying to swap cogs in the paddock.
