newbie exhaust question
Roman250
Fri Mar 16, 2012 12:16 am » Post: #1 » Download Post
I want to take off the stock exhaust to derust/paint it. Wondering if I need to take any precautions with any gaskets/seals or is removal and install a no brainer? Tried searching but just came up with lots of stuff on aftermarket pieces.
Thanks
Hobbit210
Fri Mar 16, 2012 8:18 am » Post: #2 » Download Post
Hi
It's a bit of a 'no-brainer' really...Only done it once though. Use normal tightening procedure. It would probably be a ver good idea to use new 'seals' but they are quite expensive at around £18 each. Best to do the job properly though.
Mike
Fri Mar 16, 2012 8:54 am » Post: #3 » Download Post
If you are careful, the exhaust gaskets can be reused a number of times. You can gently open them back up a little with a large blade screwdriver, but be careful that you prise them open only a little way, and do it evenly.
You can also use a very small smear of high temp exhaust sealant on them. It's not something you need to do often, so resusing them a couple of times is no big deal.
And yes, they are very expensive for what they are!
Roman250
Fri Mar 16, 2012 10:27 am » Post: #4 » Download Post
Cheers! Looking forward to cleaning them (and removing the carbon buildup with drain cleaner) and smacking some nice fresh paint on.
I used to work a bit on cars but motorcycles (especially two strokes) are new to get my hands on. This site has helped me clear a lot of hurdles and am having a ton of fun doing basic maintenance on my NSR.
Thanks for the boost of confidence.
matt
NSR-lizard
Mon Mar 26, 2012 5:38 pm » Post: #5 » Download Post
I`ve found the "exhaust" paint many auto shops sell doesn`t last long on 2-stroke exhausts, but you can get pretty good results with good old BBQ paint from the hardware store.
It will burn off too, but gives a good finish, and looks similar to OEM.
Vampire?
