MC 21 crank with alli centre bearing
Sat Mar 31, 2012 1:22 pm » Post: #1 » Download Post
Hi there has anyone ever seen an nsr crankshaft with an aliuminium centre bearing it came to me in a knackered 21 motor,one of the big ends has let go, the odd thing is the rod that let go is an nx5 conrod i have rebuilt the motor with a rebuilt crank i had in stock,just wondering if youve ever seen a crank like it,jonmac
Photobucket
Photobucket
Photobucket
toneless
Sat Mar 31, 2012 1:31 pm » Post: #2 » Download Post
Looks very interesting.
If you are pretty sure that the center part is made out of aluminum, then it is not a bearing but a labyrinth seal.
This is common on Yamaha cranks and I can't see why it shouldn't work on a nsr crank as well.
Very nice find, I never had surprises of that kind while splitting crankcases. Laughing
Please, post some more pics.
2t-racelab.com
Neal
Sat Mar 31, 2012 2:13 pm » Post: #3 » Download Post
I was going to say the same and suggest it was a labyrinth seal . I have an old racer friend that makes them and uses them on his old tz's etc .
nobby62
Sat Mar 31, 2012 8:33 pm » Post: #4 » Download Post
On the yam's they have a bearing either side of them... If its a labyrinth seal then the crank has been running on 2 bearings with no centre support.. no wonder its knackered....
Crankshaft
Sat Mar 31, 2012 8:44 pm » Post: #5 » Download Post
Hi Nobby,the crank itself isnt knackered,the centre bearing has galleries in it for lubrication and it spins over as a bearing should,the ali bearing has a locator peg also,could it have a steel race in the ali ? it is definatly smooth to turn,would a labrynth seal have these characteristics ? the only way to find out i spose is to dismantle it and have a nose inside,the big end retired on the nx5 rod the rest of it seems fine,thanks,jonmac.
nobby62
Sun Apr 01, 2012 5:57 pm » Post: #6 » Download Post
John, It would be interesting to see what it is / does..... It could be the answer to our impending doom re the shortage of koyo centre bearings. Surely it can't just be a yamaha style labyrinth seal..... Keep us posted please.
