The tank has also been repaired at some point, the base has been cut open and rewelded, I would say to knock out a dent and repainted using OEM tank stripe and wing decals and laquered. This has been done very nicely and looks a profesinal repair.
Inside of the tank is perfect with no signs of rust. I'm looking for £300, if you are interested send me a pm, I can email more detail pictures of the tank if required as well. If you want to find a postage cost dimensions of the boxed tank are 345mm x 775mm x 470mm and weight is approx 8kg (weighed on bathroom scales so not neccesarily 100% accurate)
