Also think I need item 17, 'collar', seems to be longer on the sp/se model mainshafts! _________________ More **** two strokes than you can shake a **** stick at.
I think I'll need 25's & 16 to go with 17 as it looks as if the sleeve is a smaller diameter maybe to run a beefier bearing? All new to me but if you could help that will be awesome!
Thanks!
Paul _________________ More **** two strokes than you can shake a **** stick at.
