Hi i have a mc28, fitted with tyga pipes, it runs fine but at about 5000 revs it splutters through all the gears, can anybody tell me if this is normal behaviour!
Are you using a PgmIII unit?
If yes, it sounds like an issue with the GPS system.
If not, check the carb needles, I remember there should be a washer underneath them that effectively makes the fuel mixture richer. _________________ 2t-racelab.com
