20 year old Carburetor floats
mellorp
Banned
Thu Aug 23, 2012 5:48 pm » Post: #1 » Download Post
Guys
I have a problem with fuel overflowing from one of the carbs. So far I have
Flushed the tank/replaced the filter
Replaced the float needle valves
Adjusted float heights
All seems OK but after a while, engine running or not, fuel comes from the overflow. I swapped the floats themselves and hey presto, the other carb flows fuel from the overflow pipe in exactly the same way. Before I embark on replacing (both sets of floats) do they become porous as I think this is the problem.
Thanx in advance
Phil M
Thu Aug 23, 2012 5:52 pm » Post: #2 » Download Post
Possibly, or simply damaged.
Not that it matters, if you swapped a part and the fault followed that part, then it must be defective.
Sun Aug 26, 2012 8:57 am » Post: #3 » Download Post
Mine leak if I don't keep the bike on a paddock stand.
Sun Aug 26, 2012 4:01 pm » Post: #4 » Download Post
That could well be your running problem Rob.
mellorp
Banned
Mon Aug 27, 2012 11:24 am » Post: #5 » Download Post
I have 2 new ones on order so once fitted I will let you know the outcome
Phil M ;0)
Mon Aug 27, 2012 5:34 pm » Post: #6 » Download Post
Are the float settings out of the box reliable?
Mon Aug 27, 2012 7:54 pm » Post: #7 » Download Post
Depends how big the box is, how well wrapped they were, how often the box was dropped and if anybody bothers setting them at the factory.
Suggest you set them up before you refit the whole lot and then find out they leak...
mellorp
Banned
Tue Aug 28, 2012 4:50 pm » Post: #8 » Download Post
I checked the float heights and set them both up correctly (and replaced the float needles). Hopefully the new floats will in fact float !!! AS you say if the fault followed the part, you would suspect that the part is faulty Wink
Tue Aug 28, 2012 7:28 pm » Post: #9 » Download Post
It better be or I shall feel silly! Very Happy
