MC18 fuel line
nine16
MC18 fuel line
Fri Sep 07, 2012 11:25 pm » Post: #1 » Download Post
Anyone know what size the MC18 fuel line is? 5/16" ID 1/2" OD? Also, anyone know offhand how much length I'll need to replace all of it? I'm worried 3 feet won't cover it so I may be stuck buying the 25 foot roll. Going with Tygon to deal with the ethanol we have in the US.
Dmitry
Sat Sep 08, 2012 4:43 am » Post: #2 » Download Post
MC18 line is 10mm id 3/8" would be closes SAE, it has two 90º bends in it, probably under 10" long
Do you still want the shock links?
nine16
Sat Sep 08, 2012 5:50 am » Post: #3 » Download Post
Yeah, I want the shock links.
I'll have to see if I can find any 10mm Tygon. Are the bends bad enough to kink the hose if I don't use pre-formed ones?
Dmitry
Sat Sep 08, 2012 1:59 pm » Post: #4 » Download Post
line exits the carbs and makes 90º turn because it's up against the frame, pretty sure non-moulded line will kink
Links are done, forgot to tell you.
