I've been digging through my ever expanding collection of NSR parts, and I have 2 sets of mc18 cases (and 1 complete bottom end). I was looking at the flowing of them, and noticed one of them is quite different;
Any ideas?
Paul _________________ More **** two strokes than you can shake a **** stick at.
There are a number of different diameter and stuffed cranks. These must be matched with the cases. You may find the internal diameter of the cases differ to other models.
For example R2J cases are bigger than R5K, which in turn are smaller than MC21's. However HRC cases are smaller again and use a smaller crank but which is stuffed.
Cutting away such large amounts internally often requires the use of a different crank to get the maximum benefit.
Personally I think the best crank cases for an NSR250 are MC18 R5K (modified) fitted with a HRC F3 crank. _________________ If I have to take the carbs off once more...
