I have a couple of questions for the experts about the engine condition .
I have a rough patch at about 5000 but I am wondering if this is the transition of the power valves, once through this she pulls well and have got ore 160 kph before buttoning off and there was plenty of go left.
In the process I have noticed that once I remove the air box cover when running the carbs, particularly the left ( rear) carb , I noted an oil residue in that side of the air box. I note at idle the front cylinder idles stronger than the rear. I note when I rev the engine up when the rear cylinder fires up in earnest the carb starts spitting fuel back, the right carb does it but not so strongly.
I have cleaned out and synchronized the carbs. I borrowed a compression gauge and both cylinder topped out at 90 psi.
I note the specs of the mc 16 are comp ratio of 6.2 to 1 . My calculation, possibly flawed , is that if atmospheric pressure is 14 psi then at this ratio I would expect about 90 psi but the consensus seems to be they should be much higher? I Note that older 2 stroke bikes often had these low comp ratios? A discussion with a local 2 stroke mechanic/ racer revealed he thought if the engine was tired it would be hard to start of idle poorly or be mechanically noisy.
My engine is none of these . But I am feeling now that it may be time to replace the reeds and freshen up the top end with either rings or if worn the pistons as well?
Interested in expert opinions of some or all problems. I can live with the faults as she goes well above 6000 and handles great.
Thanks
