I measured squish at 0.7mm on unleaded and between 0.55-0.6mm on leaded. Leaded head volume is around 22.6cc, unleaded 23.8cc. _________________ If I have to take the carbs off once more...
What's the squish area ratio for the two different heads?
Wishing I'd taken you up on the offer of bringing a head with me now Then again I ended up throwing half my stuff in the bin at Heathrow cos I was over weight as it was
You could post me one, or you could tell the Mrs that you're just popping over to see Granty and then hop on the plane. I'll meet you at Swensen for a triple choc Sundae.
