Stock needles for MC 21 SP
ponsone1
Tue Oct 02, 2012 10:57 pm » Post: #1 » Download Post
I have an MC 21 Sp model and just noticed that there are two different needles in the carborators. Can anyone tell me the proper OEM needles that I should be in these carbs??
Thanks
ponsone1
Tue Oct 02, 2012 11:37 pm » Post: #2 » Download Post
The ones I have in the carbs are as follows:
Top Cylinder: J3CL
Bottom Cylinder: J3LB
Are these needles correct, if not what should I be running??
Thanks,
Tue Oct 02, 2012 11:38 pm » Post: #3 » Download Post
If you check this page [Technical Resources] you will see that the TA22B carbs (type is dependant on model/year) use different needles.
The #1 carb is the left carb/top cylinder.
