Smoking PGM2. Damn.
2Smoke
1987 Honda NSR250 MC16
Smoking PGM2. Damn.
Thu Oct 04, 2012 9:51 am » Post: #1 » Download Post
During the cooldown lap on the last race at Aintree the other weekend, the bike developed a fault where it stopped revving, and gradually died. With this the voltage was dropping until it stopped. I could smell some burning from the front so thought it must have been the battery eliminator that had died.
Anyway, having just finished rebuilding it this morning, tried starting (with a battery fitted) and it refused to, the voltage gauge was showing a massive current drain and then I noticed smoke coming from the PGM2.
I switched the power off, took the battery out, removed the PGM and went to find a spare. First thought was a dodgy servo but thats all fine (or so it seems).
Checked the loom for any cable damage, all ok.
Fitted the new PGM, started ok, valves moving as they should etc.
I'm stumped! I'm using the bike this weekend, and don't want to fry my last PGM. Any ideas what could have caused this to go?
stefanos-MC28
Thu Oct 04, 2012 12:32 pm » Post: #2 » Download Post
Hi 2Smoke
Some thinks that you must check and can cause the PGM to overheat and finally burn are these below :
Power valves cables not well lubricate or cable's wires in bad condition with no smooth movement.
Power valves cables wrong adjustment with too much tension,they need 0.5mm free play.It's better more freeplay than less.
Valves on the cylinder are not clean and they have carbon on them with the result of not smooth movement.
Check out these issues as any of them overheat and damage the PGM.
Neal
Thu Oct 04, 2012 12:45 pm » Post: #3 » Download Post
Could it be related to the battery eliminator ?
Thu Oct 04, 2012 6:16 pm » Post: #4 » Download Post
Honda changed servo motor wiring at some stage during MC18/MC21 production. While maybe not whats caused your fault, if you plug the "wrong" servo motor into the wrong harness your PGM will go up in smoke.
TuckerBag
Thu Oct 04, 2012 7:04 pm » Post: #5 » Download Post
If the smoke that is put inside the PGM at the factory gets released to atmosphere,..
then the PGM stops working properly.
Apparently you cannot recharge them with fresh smoke.
Alzazorq
Fri Oct 05, 2012 6:58 am » Post: #6 » Download Post
TuckerBag wrote:If the smoke that is put inside the PGM at the factory gets released to atmosphere,..
Totally agree ! Laughing
2Smoke
Fri Oct 05, 2012 7:54 am » Post: #7 » Download Post
I've checked the cables, all free, with the required amount of slack. RC valves as free as they can be (motor been rebuilt recently)
Stephen, the servo is the same as what's been on the bike since 2010, so don't think that is the cause.
Unless the battery eliminator suddenly allowed a load of power into the PGM?
I'm going to run a battery this weekend, hopefully it will be ok, if not I'm doomed for the rest of the season!
Fingers crossed... Shocked
toneless
Fri Oct 05, 2012 9:56 am » Post: #8 » Download Post
Hi. I fabricate battery eliminators and use them on my bikes for several years.
For Nsr250 users I use capacitors rated at 20V. If there is an issue with the reg/ rec the battery eliminator dies in a matter of seconds and damage to the rest of the electronic circuits cannot occur.
I'm sorry to say that this is not the case if you've fitted a battery in there without first solving the issue as it will just boil the battery but current to the elctrics will not stop.
2t-racelab.com
2Smoke
Fri Oct 05, 2012 10:40 am » Post: #9 » Download Post
Ok mate, well it's got a volt meter so I'll be keeping an eye on it tomorrow. I couldn't see how it could have been the eliminator but just clutching at straws. Possibly when it seized the front pot, the time it was still running was enough for the servo to overload the PGM, as the valve was a bit stuck after..
It's on its last warning now!
Laughing
toneless
Fri Oct 05, 2012 10:51 am » Post: #10 » Download Post
LOL ROTFLMAO
Don't do it!
The crank on my mc28 has died on the last race, so I'm pretty much in the same mood. Rolling Eyes
2t-racelab.com
2Smoke
Sat Oct 06, 2012 6:04 pm » Post: #11 » Download Post
Ok, found the issue.
Was monitoring the voltage during a session, and it was occasionally peaking at 19v. So disconnected the reg/rec and all's well now.
And it didnt seize!
