MC28 Powervalves question
CRM
Thu Oct 11, 2012 11:15 am » Post: #1 » Download Post
Just done a top end refresh, and trying to setup the PV's
If you follow the manual, and go by the marks then at fully open - the PV's are still at least 5mm closed and could open more. Is this right ?
Interestingly even the arrow on the servo motor doesnt tally up with the markings either.
So am i missing something or is it right that they dont open all the way ?
Thu Oct 11, 2012 12:01 pm » Post: #2 » Download Post
The set up position is not full open, nor is the mark/hole on the power valve pully.
CRM
Thu Oct 11, 2012 12:04 pm » Post: #3 » Download Post
Cheers Stephen, so its right then, they remain not fully open, but i assume would fully open under real use ?
toneless
Thu Oct 11, 2012 1:17 pm » Post: #4 » Download Post
Yes, they do open fully.
If you blip the throttle you will notice that the servo pulleys move clockwise further than the markings.
2t-racelab.com
CRM
Thu Oct 11, 2012 1:54 pm » Post: #5 » Download Post
Wicked. thanks for the help.
