We had a similar problem with Tom's recently. I'm not entirely sure it is possible. No-one I contacted that day could tell us if it was possible. _________________ Andy.
If you have a '99 NX5 with power jet carbs you can disconnect the orange TPS connector, this will cycle to the power valve servo to full open. _________________ If I have to take the carbs off once more...
StephenRC45 wrote:If you have a '99 NX5 with power jet carbs you can disconnect the orange TPS connector, this will cycle to the power valve servo to full open.
Yes, this will then be the same as for the NSR's. Unfortunately I have a 96...
