the drama of fixing other peoples ruff jobs on my race mc21 goes on
at the last meet the fork seal started leaking real bad, to get me through the day I went to put a rag under the dust cap only to find an oil soaked one already there
now with the forks apart it appears the seal has been glued in!!
Clamp outer in vice using the caliper mounting points, then heat outer with a blue/butane flame where seal sits. Then yank on inner until the seal starts to move.
Thanks man, that worked sort of, it loosed the seal enough so that i could gently get it out with a small screwdriver, however the washer bewteen the seal and the bush seems to be the real issue, thats jammed in there I
That's why I said to use the inner to yank all of the parts out...This way you won't damage anything! Stay far away from screwdrivers when working with forks ! Glad it helped !
