Hi Andy.
I'm in a similar situation with my MC28 where I have I miss match of fairing bolts.
So I'd be pleased to know the outcome of **** search.
So keep me posted
Thanks
Graham
I just took the part numbers to my local Honda dealer and got them no problem about a month ago. The only ones they couldn't get were the rear and front cowling bolts. I had to order them from Steve at RS Cycles. Must warn you that they were quite expensive.
Thanks guys, spoke to Probolt & asked about any other bike that was similar. There response was no problem, if I ordered an alternate set & any fastners did not fit, they would swap FOC. Sounds good!! Any ideas which bike would be closest?
Thanks
MEM wrote:I just took the part numbers to my local Honda dealer and got them no problem about a month ago. The only ones they couldn't get were the rear and front cowling bolts. I had to order them from Steve at RS Cycles. Must warn you that they were quite expensive.
I guess I'll just quote myself here?!?! Again, you should have no problem getting OEM fairing bolts from your local Honda dealer. The only tricky ones were the rear cowling bolts.
