NSR250 Fibreglass Fairing Panels For Sale
Chester362
Tue Mar 26, 2013 8:25 pm » Post: #1 » Download Post
I've had these panels for a while and have decided I'm not going to use them now.
The full white set I bought from Dave Ett on this site for around £300.
I'll let them go for £250 for the lot, top fairing, two side fairing panels and the seat unit. There are holes for the headlight and the rear light cut into the panels. There are no fixing points for the headlight, or tail light. So if you wanted to use these for a road bike you would need to sort out some mountings. They are just white gel coat, so will need painting.
The red/white top fairing is a bit tatty. All intact but, the front mounting is a little damaged. Still useable though. I'd like £25 for this. It has the mounting points for the headlamp.
The blue top fairing is in good physical condition, paintwork is a bit tatty. I'd like £50 for this. It has the mounting points for the headlamp.
The white MC28 top fairing is in perfect physical condition. It's a Tyga race fairing. The paintwork could do with some rubbing compound, so not the best, but, passable for a race bike. The screen has a small crack which I drilled at the end to stop it spreading. I'd like £70 for this.
All prices are plus postage of course.
Cheers.
