Can anyone tell me how I can check the oil pump is not pumping through too much oil?
Is there a stock setting that it should be adjusted to (ie: 2 turns out....etc..) I think mine is chucking through too much 2t, seems to burn alot when you open the throttle and give it some revs (moving, as well as stationary).
