Hi
My MC21 has developed a problem where it stops after running for a while. I have replaced the ignition cut out as this seemed to be the initial source of the problem. However now the bike seems to run for about 10 - 15 minutes then stops. The suggestion seems to be that the PGM III is malfunctioning when it gets warm. Does this seems correct? Is the PGMIII repairable? There is a possibility the PGM has had a knock at some stage so I am unsure how robust these units are.
Appreciate any words of wisdom or advice.
Paul
PK
