New member sadly having to ask advice already
choochoothomas
Thu Jul 25, 2013 2:49 pm » Post: #1 » Download Post
Hi, signed up about a week ago and own a 1990 NSR 250 R7L ,I have owned this a couple months now and purchased it after a full rebuild? however on riding I found gear change was stiff and difficult to find neutral I put it down to incorrect clutch adjustment and stiffness after rebuild ,after further rides and adjustments no better so I took the gearbox out only to find that the oil/water pump drive gear has started to break up with the sheared teeth in the bottom edge of the gearbox and in oil filter, lucky I found it otherwise possible engine seize if it stripped completely, I am not sure if this could possibly be the cause of poor gear change but I am in the process of checking the gearbox and fitting new friction/steel plates, This brings me back to the oil/water pump drive Gear, I have been onto David silver and they say the drive is discontinued and gave me a part number 19215 KF3 770 I cannot seem to source one anywhere .
So here I am asking you guys if you can help.
Thanks. Rolling Eyes
MEM
Thu Jul 25, 2013 7:31 pm » Post: #2 » Download Post
Hi Thomas and welcome to the forum. I was looking for that part a while ago. It was tough to come by as, yes, they are discontinued. I ended up finding a nice used one in great condition. I'd offer it to you, but it's the only one I have and may need it in the future. However, a member on here by the name of quickninja said he had a new one that he was willing to part with. I never ended up buying it from him as communication was not great. Try him, maybe you'll have better luck dealing with him than I did.
Michael
choochoothomas
Thu Jul 25, 2013 8:20 pm » Post: #3 » Download Post
Hi MEM, thanks for your reply . I may have found a second hand one not far from me from a member on this forum. You are right about tough to find and may be wise to stock up if these are prone to failing?
Regards
Thu Jul 25, 2013 8:45 pm » Post: #4 » Download Post
This part does seem to be a common failure, but I guess you can't expect much a piece of 25 year old neoprene
What I'd be interested in knowing is if the MC28 part is the same dimensions, as it's still available
