Heat wrap on exhaust
mighty max
Tue Aug 20, 2013 1:12 pm » Post: #1 » Download Post
Hi, is it possible to heat wrap on our nsr Chamber exhaust as my right boot(heel) keep melting and burn.
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Tue Aug 20, 2013 1:18 pm » Post: #2 » Download Post
Wrapping the pipe not only stops your boots from melting but also keeps heat in the chamber.
This may be a good thing depending on other factors, but you may find that you need to rejet to suit, as a hotter pipe basically acts like a shorter pipe as sound waves travel faster as the temp goes up.
What this all means is that the pipe will then be tuned for a higher rpm, so you'll find that the engine becomes a little more peaky. Depending on how much of the pipe is wrapped of course.
mighty max
Wed Aug 21, 2013 12:45 am » Post: #3 » Download Post
Thanks Matt..
