Hows it going new here, just looking recently at buying a mc16 nsr needing a lot of work, ive did a quick search on google but not much coming up so heres a few questions for those of you who can answer them!
Where do you buy rebuilt kits, top/bottom end, main bearings, seals, gaskets etc? Not looking for genuine HRC but at the same time something that will do the job.
The bike is sitting up a long time so id be rebuilding it, with a top end and probably a crank, would I be better off sending the crank to get rebuilt? (how much??)
Hi,if that's the bike from West Cork,you've got a lot of work to do!However,if you use the search function here,you'll find most of the information you are seeking.As for parts,the classified section here is useful,and have a look at the Vendors Area,parts may be available in Japan and elsewhere.Be prepared to open your wallet tho'
