As I recall, without running down stairs, the HRC ones don't have dust seals in front of the wheel bearings, 1990 HRC wheels had a 3 disk bolt fitting and 1991 had a 4 bolt pattern. _________________ If I have to take the carbs off once more...
Thanks and what is the benefit of the HRC ones, are they significantly lighter? Reason is I have seen one for sale but want to be sure it is an HRC one (Looks to be genuine, has original stickers etc,has 3 bolt disk pattern) and whether it is worth it over the stansdard SP magtek rear wheel
