drunkn munky wrote:Thanks but how do you work that out from the parts book as a number of the colour schemes are coded R109
The "L" in the circle is the Model Year (1990), which corresponds to only one colour scheme associated with the code R-109. If the colour had been NH-196, however, you'd be in trouble! (There are more than one.)
Ciao, _________________ JZH
London, UK/So.Cal, USA
www.vsource.org
That code tells you what the original fairings were associated with that subframe, keep in mind they are old bikes and parts may have been swapped out before.
Thanks, well either the subframe or the wheels and forks have been changed at some point in its life as subframe points to type 3 as above and wheels and forks are type 4
Hello. I've been trying to figure out how to use the manual to find my factory colors but I don't see it. Can somebody show me where to find it? Thanks.
