Anyone have any tips on straightening a frame?
ripready
Wed Jun 22, 2005 3:21 pm » Post: #1 » Download Post
Hi,
I have a frame that has the mounts for one side of the rear sets bent inwards. It looks like the bike took a slide and bent the rear set along with the frame. Any tips on straightening this?
Thanks
Rip
Wed Jun 22, 2005 3:27 pm » Post: #2 » Download Post
Yeah, two tips...
    1. Don't do it... just find another frame - there's enough of them about!
    2. If you really must, have a professional do it!
There's just too much at risk by straightening it yourself. If that mount fails while you are at 200kph because you failed to treat the metal properly before and/or after straightening it, who knows what may happen!
A professional will (should) be able to x-ray and/or stress test the mounts after the job is done too, something you can't.
It just ain't worth the risk!
JohnBlaze
    Send private message View user's profile Visit poster's website AIM Address
Wed Jun 22, 2005 3:46 pm » Post: #3 » Download Post
you can always try GMD computrack. theyre worldwide.
ripready
Wed Jun 22, 2005 5:11 pm » Post: #4 » Download Post
I hear ya on the cracking thing. Just wanted to make sure I was clear in describing where the damage is. The two tabs that stick up from the main frame (where the rear set bolts onto) are bent in. There is actually no damage to the main frame just the tabs. Would you still recommend not fixing it?
JohnBlaze
Wed Jun 22, 2005 5:50 pm » Post: #5 » Download Post
http://www.gmdcomputrack.com/
if you want a perfect frame Wink
