MC21 Running Issues
rhyshrc
MC21 Running Issues
Thu Apr 17, 2014 1:43 pm » Post: #1 » Download Post
Having a problem with an MC21 SE, someone may have some ideas?
The bike will not idle on 2 cylinders below 2000rpm, below 2000 the front cylinder just cuts out. If the idle screw is turned up so the bike idles at 2000rpm or above it stays there fine.
The idle is solid on 1 cylinder and does not hunt around etc and the bike will hold a constant rpm on the throttle. Above 2000rpm the bike runs fine and pulls all the way through the range as expected.
There is a noticeable 'chuffing' noise from the right hand pipe when the bike is being revved in neutral once the throttle is released whilst the revs drop back down.
The bike does not smoke more the usual.
The bike has around 10,000km and we believe it to be on the original engine.
We have already checked for air leaks on the intake, balanced the carb slides, replaced both plugs, set the oil pump, cleaned the carbs + jets, replaced a missing reed gasket but the bike still wont idle under 2000.
It may be useful to add that the bike can be hard to start when hot.
The bike is totally standard apart from a wiresplice.
Any advice would be appreciated
nxrsr20
Thu Apr 17, 2014 8:28 pm » Post: #2 » Download Post
Have you down the crank seal leak test?
nobby62
Fri Apr 18, 2014 7:55 pm » Post: #3 » Download Post
I had near identical symptoms a couple of years ago.... I feared the worst as it seemed very serious with the exhaust chuffing and cutting out below 2000 rpm. However the first thing I did was put a brand new plug in and that cured the problem..... I wouldn't previously have thought that a duff plug could give such symptoms, but it certainly did... I have never had the issue since.
rhyshrc
Fri Apr 18, 2014 11:10 pm » Post: #4 » Download Post
We have tried multiple sets of new plugs but haven't done a leak down test.
kan3
Fri Apr 18, 2014 11:51 pm » Post: #5 » Download Post
I would do a comp test then a leak test if the comp test looks ok
mellorp
Banned
Sun Apr 20, 2014 3:11 pm » Post: #6 » Download Post
Clean the carbs (again) air screws, pilot jets or some such. Once the throttle opens the smaller jets impact on things is minimised
HTH
Phil M
