Some measurements
George
Some measurements
Mon Jul 28, 2014 7:44 pm » Post: #1 » Download Post
Hi to everyone.
I need some help from you guys.
Can someone do some measurements for me please.
With ignition key set ON and ignition switch set to RUN.
All i want to know is what voltage readings you guys get when try to check the voltage between these wires at the wiring diagram of mc 21 model.
The wires are this that goes into the ignition coils.
First i need to know the voltage between the Black/Yellow and Green/Brown wires at one ignition coil
And the other wires on second ignition coil Black/Blue and Green/Brown wires.
Thanks.
Mon Jul 28, 2014 8:29 pm » Post: #2 » Download Post
Please use the search. There is a very detailed post on this, complete with photos.
