Looking for front brake line specs, MC28
dan rudd
Tue Nov 04, 2014 5:12 pm » Post: #1 » Download Post
I found a split fitting on the front brake of my MC28. The brakes are Brembo's which is the way they were when I bought the bike. One of the female fittings on the braided line split where it screws onto the banjo bolt.
When I call the local Honda shop they are stumped because they don't see NSR's here in the states and claim they can't get parts for them. I don't know for sure but I'm guessing the brake lines are similar to those used on US bikes such as the CBR etc.
Can someone give me the fitting size and the tube diameter if they know it? I'm guessing the fitting is 10mm but not positive. Also I don't know if it's some type of compression fitting, flared fitting, or something else I'm not familiar with.
Thanks,
Dan
eyrey1
Tue Nov 04, 2014 11:46 pm » Post: #2 » Download Post
cant you send it off to get someone to copy it or just measure the lengths and joint angles and get someone to knock you one up !
you can get the bits on e bay and make them up yourself !! it is pretty easy
